Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
remove the top cover,then on the inside look for a loose clothes baffle inside the drum that turns the clothes,then from the top you can replace these baffles or tighten them
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
To tighten the drum baffles, all you have to do is UNPLUG the dryer and lift the top panel. The bolts that hold the baffles in place are located on the outside perimeter of the drum. There's usually a minimum of two per baffle. If you cannot figure out how to lift the top panel, post back with your complete model number (located on a nameplate around the door opening or back of the operator console) so that I may be able to assist you further. I hope this helps you.
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
