Anonymous Posted on Jul 22, 2008
Zipy Kanguro Radio Tuner
I just bought one of these and cannot for the life of me get the radio to work on it.
I tried reading the manual that comes with it and it doesnt really help as it says it will play automaticly but doesnt.
I have done the searching and saving of channels bit but nothing happens it just stays quiet.
Any help much appreciated as I hope im just doing something wrong and its not faulty
A
Anonymous
The radio does not work without the headphones plugged in. Also, make sure that you have set your region in the settings.
A
Anonymous
Most small devices rely on the wire plugged into the earphones jack to be the antenna to receive the radio signals, so if you are trying to listen to the radio through the builtin speaker without having earphones plugged in, you might just not be getting a signal, and since it is a digital tuner, it probably can tell that you are not getting a signal and so just outputs no sound, not even static.
so try plugging in some headphones if you haven't been doing that.
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
1helpful
How do I display the radio ID number, so that I can listen to Satellite radio?
Verify if the radio is "Satellite ready" or if it comes with the remote tuner unit. I believe you have to buy a separate tuner add-on and antenna in order to activate the satellite circuitry - THEN it will show you a radio ID. I think ONLY the Alpine comes with the tuner. I would call Crutchfield and they can tell you what all you need with that tuner to make it work with the satellite radio.
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
2answers
Hi, I have a window7 toshiba satallite pro, laptop.and I need fm radio tuner software to download, Is it posible in any site? pls help me.
Hi there , Try using http://www.sharewareconnection.com/titles/radio-tuner.htm
Hopefully you will come right.Good luck
Thanks
11helpful
2answers
How do I manually tune a Ford Focus 6006 Radio
Press the Menu button. At some point it'll put an 'M' next to the station frequency. Then hit the seek up and down button.
1helpful
FM Radio
Hi
iPods do not come with FM tuners. FM tuners can be bought and added on as an extra feature, but this is a third party device, not an iPod device.
Generally, when you connect the third party FM tuner to the iPod, the iPod will recognize it and you can use the 3rd party FM tuner to change stations.
If you do not have the FM tuner to connect to the iPod, the individual that sold you the iPod did not include the FM tuner to connect to the the iPod. In that case, the Menu will still list the FM tuner, but there is no device to connect to the iPod.
FM transmission on a zipy kanguro
I solved the problem...just plug the earphones...
1helpful
5answers
My zipy kanguro mp3 mp4 player won't turn on other than the red light by the menu imprint. Any suggestions?
any1 knows how to use the cd? becuase my zipy knaguro doesnt support m4a files and avi video..
please help me
2helpful
2answers
Car radio not working
Sound like you need the manual to this radio, I would have said that there are components inside that go bad that will cause a radio not to light up in the display area. But if you radio is saying tuner, and maybe cd then it would be the selector button that has a problem. Or no antenna is hooked up or come apart.
 Grubhead
Grubhead
SmartAviator
SmartAviator
