SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
SOURCE: Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
SOURCE: I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
SOURCE: Im putting in new stove. i have 3 wire(6 gauge)
You should have three terminals on the back of the stove the middle is neutral if you measure from the line on the left to the line in the center you should get 110 and the same from right to center.test each line from the stove to ground if you have power on the middle one it is hooked up wrong.
SOURCE: I too have an Admiral stove and the top 4 burners
If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number, we can attempt to diagnose this problem for you.
We look forward to getting you cooking again.
