This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
For this problem, its indicating towards
problem with damper assembly.----------
The working procedure of this unit is as
follows: --- The compressor starts then it cools the freezer section. When the
freezer reaches its cooling level the defrost cycle starts functioning. In this
cycle the fan in the freezer section starts running and the cool air in the
freezer section is passed to the fridge section and the fridge
section gets cold. The air from freezer to refrigerator passes from the
section, in that section the damper is located. ----------- The damper is
operated by a motor.Its a complete damper assembly with motor included in
it.--The damper has door.Which closes and open with the help of motor.In your
case the damper door is remained open, its not closing.Due to this the cool air
from freezer section is running in to fridge section non-stop.Due to this the
vegetables and other food in the bottom drawer freezing.--------- In this
problem the damper assembly needs to be replaced.---------------
You can get
required parts from online sites like: --- www.repairclinic.com
or from searspartsdirect online site. ----------- This should help.
Thanks.Helpmech.
