Thank you for contacting FixYa with your printer inquiry.
http://www.laserprinterservices.com/parts.html https://www.partsnow.com/Forms/Login.aspx http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html Hope this helps helps. Please keep us updated and remember to rate this answer.
This is usually a paper pickup error where paper pickup roller is not contacting the paper in the default paper tray or Pickup roller is worn smooth and not picking up the paper.
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding.
Solutions:
Make sure the paper size adjuster in the tray (Paper Backstop) is against the paper and correctly set for paper size.
Paper roller slippage - Needs to be replaced. Order a new one. Clean with water or alcohol in the interim while waiting for replacement. Eliminate all the paper dust. Sometimes works.
Part Number:
RL1-1370-000CN Paper pickup roller - Picks up media from the paper input tray.
Venders:
http://partsurfer.hp.com/Search.aspx?SearchText=Q7814A - HP Parts Surfer
