SOURCE: "Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
SOURCE: Olympus Stylus 770SW error message
After only 15 days mine did the same thing. I called the dealer Olympus and they gave me a RAN number and told me where to send it. I got a call about a week later. They said because the camera had moisture inside I was not coverd. The best they would do is mail me a rebate card for 25 dollars off my next purchase. I was like WTF. The woman said sorry but that was all they could do. When I asked to speak to manager she hung up.
SOURCE: Card cover open error message...
The problem you are describing is a problem with the sensor on the card cover door It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service. http://olympusamerica.com/cpg_section/cpg_servicerepair.asp Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $101.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: card cover open
The problem you are describing is a problem with a sensor that is on the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.http://olympusamerica.com/cpg_section/cpg_servicerepair.aspOlympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $124 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
