REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Testimonial: "Many thanks for your fast and accurate advice and solution. We have now ordered this unit and will install as you suggest."
Those waste boxes are expensive. After removing it from the machine, just put it in a garbage bag and shake all the toner out , then open the bag enougnh to get the waste container out, and wipe it off with a rag, then place back in the machine.Tie the bag shut, and toss it out....Too bad Sharp isn't ecology friendly. They also have disposable toner cartridges, that could easily be refilled, at a much lower cost, but refuse to do it, and the warranty on the machine is invalid if you use any aftermarket toners.
