Question about Jet Tech Systems Refrigerated Display (Sushi) Case counter top 56
Our company has started manufacturing frost free display cases for Pastries & cakes. The problem we are facing is we are getting a lot of frost on glasses during the operation cycle. Due to this problem we are really facing anger from a lot of our customers. Kindly support
    New Friend:
  • 16 Answers
Make up a way to blow warm air from the condenser over the glass and your frost problem will disappear! The higher the temperature of the air - the more moisture it can absorb. The reason you are having the problem is that you are cooling moisture laden air and it has to give up the moisture as you cool it. So run some warm air over it and it will absorb the moisture for you = problem gone.
koolman77 (refrigeration technician)
Posted on Feb 07, 2011
6ya staff
SOURCE:
Where can I find a Sparta long reach pastry brush?
http://www.kitchenhaven.com/page/100/PROD/201300000/36520
Apr 10, 2013 | Home
When bread is cooked in a bread machine, the bread sticks to the paddle & makes large hole in base of bread
Most bread machines do this from time to time. One thing you can do to lessen this occurence is to choose light crust option on the control panel
Aug 07, 2011 | Kitchen Appliances - Others
I lost my instructions for the recipes and i don't know how to make the cake mixes
I have the recipe for yellow cake from the handbook:
preheat over for 15 minutes and spray pans with cooking spray
1. pour contents of yellow cake mix into bowl and stir to break up any lumps. 2. add 1.5 teaspoons of water and stir to form batter 3. pour batter into baking pan and spread evenly. 4. place pan in baking slot of oven and use pusher end of pan tool to push it into baking chamber. Do not use your hands. 5. bake cake for 12 minutes. 6. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 7. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. Transfer cooled cake to a plate, turning over so bottom faces up.
frosting 1. pour contents of frosting mix into bowl. 2. add 1/2 teaspoon of water and stir until smooth. For thinner frosting, stir in a few extra drops of water. 3. spread frosting over cooled cake.
Sugar Cookies
1. pour contents of sugar cookie mix into bowl and stir to break up any lumps. 2. add 3/4 taespoon of water and stir to form dough. 3. sprinkle your hands with flour and shape dough into 6 small balls. 4. flatten 3 cookie balls and place in baking pan. 5. place pan into oven and use pusher end of pan tool to push into oven. Make sure both metal doors are closed. 6. cook for 10 minutes. 7. when baking time is complete, use pusher end of pan tool to push pan into cooling chamber and let cool for 10 minutes. 8. when cooling time is complete, use holder end of pan tool to remove pan from cooling chamber. 9 repeat steps 4-8 to make remaining 3 cookies.
those were the basic recipes in the handbook. Hope that helps
Jul 25, 2011 | Hasbro "easy Bake Oven and Snack Center"...
I got a Disney Christmas cupcake set for Christmas from Walgreens but the "cake" recipe directions are not correct. I have 2 small bags of cake mix in the box & it says to add 2 eggs & 4...
Both of my kids got one of these cupcake sets. I called Walgreens customer service on this but they said they were going to have to get an answer from the manufacturer on this and that it might take a couple days to get back to me. A lot of people have been calling this in, I'd suggest you all do the same so the company can see just how many people have been having an issue with this.
Now on to my experimenting! My 5 year old was standing on a stool with all the stuff out ready to go as I was on the phone with customer service. When I couldn't get an answer I couldn't tell my son no any longer so I decided to go ahead and follow the instructions. There's a second kit around here someplace anyway. First off the oven temp converts to 356 deg F, mine would only do 355. I used the two packets in the cake mix box with two eggs and four teaspoons of butter. Let my boy stir then broke out the electric mixer. Once all mixed there was just enough for 12 mini cupcakes. The baking time was off by a lot. 10 minutes was not enough, ended up being more like 25. I took them out when the tops started to look brown. Did the toothpick stick and no cakey bits stuck to it. They end up being spongy but otherwise okay.
As for the icing, use both packets and the 2 tablespoons of water, but you really have to use a mixer on high speed to get it to whip up. We never used the little 1/2 cup measuring cup, the instructions never called for those increments, but it's a cute bonus!
I hope this helps!
Dec 28, 2010 | Toys
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Refrigerators Logo
Top Jet Tech Systems Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Jet Tech Systems Refrigerator Expert? Answer questions, earn points and help others
