If only one color is not working - it is usually just the connector of the screen or the monitor cable itself that is faulty. Remove the Monitor Data cable that plugs into your PC and check that NO pins are bent or pushed into the socket - then re-insert the VGA connector into the PC and make sure that the part of the cable that plugs into the monitor itself is also secured properly. That should solve the problem. If not - it could be the cable itself - bend the cable at the connector to check for a lose wire inside. If the color suddenly comes back - replace the data cable to the monitor.
Hope this helps
Good Luck
