I have a humminbird wide it has always worked great but recently it will not detect fish it reads the bottom fine but that is all it will do. any suggestions?
Make sure the transducer is level and also make sure your beam is set to wide. If you have theses suggestion in place there should be no reason that you can not see your jig.
This could be a lot of things. The unit employs multiple signals to gather data and it could be the transponder not getting the signal or it could be something simple like the sensitivity. Humminbird 757c Operation Manual Sensitivity
Fish on the bottom show as a blur, similar to weed, and pelagics show the same, but because of there position they are easy to recognise. Large singe fish like schnapper and sharks tend to show as an upside down V. You will have to use it often and you will eventually, by experience be able to tell whether you are looking at fish or weed.
you can download the manual from the below link...
http://www.humminbird.com/PDF/100sx.pdf
a very helpful rating wud be appreciated for answering ur problem...
regards
the base that the unit plugs into has a plug in for the transducer and one for the power. make sure that the power plug is pushed in far enough on the mount so the unit gets power. then tighten up the screw that holds the two in place.
