Roxio Easy Media Creator 7 Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i uninstall roxio easy media creator 7 forever off my hard drive?
Julie Endres
Level 2:
Sergeant:
Champion:
  • Expert 209 Answers
  • Posted on Feb 06, 2011
Julie Endres
Expert
Level 2:
Sergeant:
Champion:
Answers
209
Questions
Helped
34762
Points
620
Go to start button, control panel, uninstall programs under the programs catergory. Find the Roxio program you want to uninstall. Click on it and click uninstall at the top of the window. That will start the uninstall wizard. Follow the prompts to uninstall. You may need to restart your computer afterwards.
Disc
It may be a conflict with another program. Roxio is a little tempramental about other software.
You can try another Burning software to check the drive is not faulty.
You can try a free program like IMGburn.
If that program works i would uninstall roxio, run a registry cleaner. I like CC cleaner's built in registry cleaner.
Then re install roxio and check the roxio site for any updates
7helpful
Is Roxio 9 compatibility with windows 7?
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Computer does not recognize the usb. Installed software, started to capture video, then it quit and hasn't worked since Roxio Easy VHS to DVD for Mac
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
Roxio's Easy Media Creator 9 Windows XP locking up
uninstall it or if you cant start your computer reload windows from disc. media creator may be too "big" for your system. pentium 4 min.required,i should think no easy way out if its crashing your computer
I seem to have misplaced disc 2 of Roxio Easy Media Creator 7 - disc 2 contains the content. I have Disc 1 which is the main applications. I have to reinstall the program because of a computer problem but...
Below is a download for the full version of Roxio Easy Media Creator 7.8
You can get rid of that disc, and download the one from the link. You can burn that to a disc after its done if you want for backup purposes.
http://download.cnet.com/Roxio-Easy-Media-Creator/3000-2646_4-10409252.html
Enjoy, Thank you for choosing Fixya!
2helpful
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
http://kb.roxio.com/content//kb/Creator/000217CR
Deadog4201
1helpful
2answers
Have Roxio 7 and want to install it on Windows Vista
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
I purchased a download from Roxio 02/24/2005 Easy Media Creator 7 I also purchased Easy Medioa Creator 7.5 upgrade 05/31/2005 Lost both after hard drive failure Cannot find info to Reload
If you payed with paypal you should be able to produce a receipt and contact Roxio via e-mail... they want your business..tell them what happened..they may just give ya a free dl..
2answers
Roxio media creator 7
goto this site and reinstall it for free http://www.brothersoft.com/downloads/roxio-easy-media-creator-7.html or goto cnet.com for the driver.
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Top Roxio Computers & Internet Experts
 Grubhead
Grubhead
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
