Garden Logo
Posted on Feb 06, 2011
I have a speedy green 2000 broadcast spreader and need to know what setting I need to use to spread 40 lbs per 2000 sq ft dolomite peletized lime? Thanks.
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Feb 11, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
15146
Points
21
First 40lbs per 2k of lime will do nothing, rate to chemnge ph 1 point is 50lbs per 500k which would be all the way open slow walk. for your application you should be about half to 3/4 open normal walk
  • Andrew Oct 05, 2013
    what do you mean by 500k?
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
59148
Points
89
Listed below are the SpeedyGreen 2000 suggested spreader settings for lime:
(Please note that these are not exact measurements but they are close enough for lime applications)
30# per 1000 sq. ft. - Setting of 10
40# per 1000 sq. ft. - Setting of 7.5, go over the area twice
50# per 1000 sq. ft. - Setting of 7, go over the area three times
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
2helpful
What are the settings for 5 lbs. 1000 sq ft on a scott speady green 2000
the low end od the stting bar is for 1/2 pound per thousand sq ft each mark adds 1/2 pound
4helpful
5answers
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 • Garden
I have a Scotts Speedy Green 2000 rotary spreader and want to know the proper setting for your Milky Spore 20 lb. bag (granular carrier). I have been keeping it about 50% open (Setting # 9 to 9.5) but it...
I have the same question, but have not found a direct answer. I have calculated an estimate setting of 4 or 5 for the speedygreen 2000. The Milky Spore is very simular to the fertilizer that I use. Milky spore says that 1lb covers a little over 300 square feet. My fertilizer says that at a setting of 4 it is spreading 2.6 lb per 1000 square feet (almost 3 lb per 1000 sq ft or 1 lb per 333 sq ft).
Now I may be totally off, but just bought the Milky Spore today and will apply tomorrow. I may look some more tonight to see if I can find an answer. I felt it was kind of bad that the back of the Milky Spore suggested only using a drop spreader!?
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
13helpful
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Top Scotts Company Garden Experts
Jay Finke
Jay Finke
john h
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
