Click here and find the password by yourself...
pls rate the solution...
Hi brendflores,
Welcome to Fixya. Im not quite sure what password you're referring to if ti's the router password or the Network Password or Network Key. Listed below are the steps on how to obtain the Network Password and the Router Password.
For you to get you Security Code or Network Key you need to access your router.To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can change the security type of your router to WPA, WEP or you can also Disable the security. Under that you can see the Security Code or Network Key. You can also Personalize the Passphrase or Network Key so that you can easily remember it.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
If you think this is helpful rate me and don't forget to say thanks. Thanks for using Fixya.
