Hello there! My name is Becki, and I am with DISH Network. I do hope that this has been resolved for you! But if not, here are some steps that you can try. I hope this helps!
You will first want to put your TV on channel 3.
You can use RCA (red/white/yellow) cables to hook up the receiver to the TV.
If you are using a receiver that works 2 rooms, on the back of the receiver, the location for the RCA cables will have a green TV symbol with a 1 on it. That is where you want to connect these cables. Run these then to your TV. Some TVs will give you an input number next to these connections, such as Video 1 or 2.
After these are connected, try to cycle the inputs on your TV. You can do this with the buttons on the side of the TV, or with the remote. Go slow, becuase it can take a few seconds for the input to actually change. If this does not work, try to go to channel 4 and repeat the steps.
You could also use coax cable to connect from your receiver to the TV. The connection on the back of the receiver will simply say channel 3/4. And that is just what you do, put the TV on channel 3 or 4.
If these steps do not work, or you need some clarification, please let me know!
Becki Barned
DISH Network Customer Service
[email protected]
