Amazon Kindle Wireless Reading Device Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1. My kindle keeps freezing. 2. When not frozen, it frequently reboots. I've tried the restart as recommended and this was helpful for a few days. Now, my kindle is completely frozen (no light on, recharging does nothing). Help, I have owned the kindle for only a few months and am totally frustrated!!!!
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
24763
Points
91
I had the same thing happen to my kindle. I contacted amazon customer support and within the week they sent me a replacement kindle free of charge!
honey
Level 3:
Master:
  • Amazon Master 262 Answers
  • Posted on Mar 03, 2018
honey
Amazon Master
Level 3:
Master:
Answers
262
Questions
Helped
320286
Points
1535
There may be the issue with the Memory overflow or with the operating system of Kindle Device Just check the Memory storage Kindle Technical Support Registration 877 690 9305
2answers
Kindle paperwhite won't respond to "Swipe to unlock Kindle. Seems frozen. What do I do to unfreeze it?
Restart Your Kindle Paperwhite. Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation). Press and hold the Power button for seven seconds until the Power dialogue box appears, and then tap Restart.
Amazon.co.uk Help: Quick Fix: Restart Your Kindle Paperwhite
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=201176080..
or go to this link might help you out... Kindle paperwhite won respond to Swipe to unlock Kindle Google Search
tip
How to reset the Amazon Kindle (useful when the unit is frozen)
Hi.
The Amazon Kindle is known for having several firmware issues, and it is not unusual seeing the unit freezing and not starting.
To start you can attempt doing a soft reset. To do a soft reset press and hold the <ALT>, <Shift>, and <R> keys simultaneously. The Kindle display should go blank for few seconds, and then restart.
If your Amazon kindle is still frozen, try resetting the unit to factory default settings with the hard reset procedure below. Procedure is different, depending on the Kindle model.
All you have to do to reset the Amazon Kindle 2 and Kindle DX is pressing and holding down the power button for about twenty seconds, then release the button and let the unit restart.
If instead you have the previous model, the amazon Kindle one, then you will need to open the back cover by pressing it and sliding it to the right with your finger, same as when you have to replace the batteries.
Behind the cover you will see the reset hole switch.
Push and hold a sharp pointed object, like a paper clip, or the tip of a pencil inside the hole button located under the battery cover.
Wait about ten seconds until the Kindle restarts and resets to default settings.
The last procedure and the picture below refer to Kindle one only. If you have kindle two, then please use the first procedure.
If the above does not fix the problem, then the unit is faulty. In that case contact Amazon to get support.
Regards.
My Kindle has frozen and displays the message YOUR KINDLE NEEDS REPAIR.
Hello
You can solve many issues with your Kindle, such as a frozen screen or issues with downloading content, by restarting your device. Help for Kindle Paper white (5th Generation).
To restart your device:
    1.Press and hold the Power button for seven seconds until the Power dialog box appears.
    2.Then tap Restart.
    For any help visit us: www Kindle Com Support
Kindle paperwhite keep freezing or won't let me swipe to change page
I always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
1helpful
2answers
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
1helpful
2answers
My kindle is frozen it wont let me search for new books
The Kindle touch and the Kindle FIre are great devices for you reading needs. However, there are time when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose you data during the reset process, make sure you have made a backup of your files before proceding.
Hard and Soft Reset
  • Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state. hope this helps
3answers
Kindle froze
Perhaps the wrong format pf ebook?
11helpful
4answers
In most cases, to avoid freezing, keep battery charged and turn off wireless when it's not being used. To properly reset, hold power switch to the right for 15 seconds.
Resetting the device is not a bad thing, most electronic devices need it to be done. It can be annoying, but it's not fatal.
I would keep track of how many times you need to reset the device. Once the amount get over a few times per day, honestly, I would call Kindle Support. They've got the necessary software to look further into your Kindle.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
