Question about Cell Phones
I have model 1104 sensaphone and lost manual. I want to know how to change dial out numbers
    New Friend:
    Problem Solver:
  • 6 Answers
To change the phone numbers in the Sensaphone 1104 press [SET] [phone number] <1-4> then enter the telephone number you want the unit to dial, and press [enter]
*Remember to program the telephone number JUST how you need to dial it from that location. If you do not require a 1 or area code do not program it in, as this can cause the dial out to fail.*
Here is a link to the manual if you need one. Also, since this model was discontinued, the direct replacement for this unit would be the Sensaphone 400.
Sensaphone 1104 Manual:
http://www.sensaphone.com/legacy-products/1104Manual.pdf
Sensaphone 400:
http://www.sensaphone.com/products/sensaphone-400-monitoring-system.php
Posted on May 13, 2015
SOURCE:
Check temperature and all it say OK
You might have to have the temperature sensor: http://www.sensaphone.com/products/contact-type-temp-alert-temperature-switch.php . Do you have it? If so, let me know and I'll try to help. If there is anything else I can do, just let me know!
-Mr. W
Sep 16, 2014 | Sensaphone Alarm Monitor - Model 800 -...
Why is the green light going on and off on my senaphone modle 400?
I'm assuming this is the System On LED on the Sensaphone 400. That would indicate that the unit is in standby mode. All you will need to do is Press the [Run/Standby] key this will turn the Sensaphone back On. The system On LED on the Sensaphone 400 & 800 flash when the device is in standby mode, solid lit when the device is On. If these units are in standby, they do not recognize alarms nor do they pick up the phone on a dial in.
Here is a link to the manual if needed
Support Sensaphone 400 Monitoring System
Jul 28, 2014 | Sensaphone Alarm Monitor - Model 400 -...
Password for ims-4000 console
The Sensaphone IMS-4000 Default Password for the Console View Software is :
Username: admin
Password: ims4k
The software is available for free download here:
http://www.sensaphone.com/pdf/IMS4000ConsoleViewSetup.zip
Dec 14, 2013 | Sensaphone IMS-4000 (ims-4409)
I can't logon to my Sensaphone IMS-4000 Host as I have forgotton the password
You will need to log in to the IMS-4000 through the serial port using a terminal Emulator such as Hyper Terminal, Putty or Tera Term. Option Number 9 on the menu will enable the Default User acct. This will allow you to login with the default Username: admin Password: ims4k
Once logged in, make the correct changes to your existing profile.
If you need more information here is a direct link to the manual:
http://www.sensaphone.com/pdf/LIT-0064_IMS-4000_Manualv3.0_WEB.pdf
Sep 16, 2011 | Sensaphone IMS 4000 Host Unit (IMS-4001)...
Speed Dial
Select the model of the phone from the list at
http://www.uniden.com/index/manuals_results.cfm?cat=1
May 20, 2010 | Uniden Cordless Phone
I have Comcast bundle service for my home that includes tv, phone and internet which is digital. Can I use the Sensaphone 400 with this digital system?
This model may not be used on a digital system. It can be used on a standard phone line only, only engineered to handle standard phone line with pulse or tone dialing. I hope this helps!
Sep 20, 2009 | Sensaphone Computers & Internet
MY MSI DRIVER CD IS LOST
if this is ur MOBO Model No: MSI > K9MM-V Motherboard
then here is the link of all drivers
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1104
pls rate me Well !
Mar 25, 2009 | MSI K9MM-V Motherboard
How to enter name of the telephone # on speed dial
Go to HP's website and look under downloads or manuals. You should find your machines model from there and then you can download it to your PC for future reference. Please let me know if this helped. Thanks!
Feb 13, 2009 | HP 920 Plain Paper Fax
Stored quick dial no,s
PLS LET ME KNOW THE MODEL NUMBER OF YOUR DEVICE !!!!!
Dec 02, 2007 | Computers & Internet
Open Questions:
Cell Phones Logo
159 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
