SOURCE: I need a new blade
Coleman really **** big ones for not having spare parts i have the same problem.If you rap the steel rod with plumbers teflon tap it dose stop the leak just use more at the handle end.Hope this helps
Turn off the water to the fixture.
Flush the toilet and hold the handle down to let as much water out of the tank as possible.
Sponge the rest of the water out so the tank is dry.
Remove or undo the water supply tube from the fill valve.
Remove the three bolts holding the tank to the bowl and remove the tank.
Replace the old seal with the new one and reverse the whole process.
You should be good to go.
Good luck.
