Vizio E370VL 37 in. LCD HDTV Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
John Phillips
Level 2:
Scholar:
New Friend:
  • Expert 70 Answers
  • Posted on Feb 06, 2011
John  Phillips
Expert
Level 2:
Scholar:
New Friend:
Answers
70
Questions
0
Helped
37841
Points
202
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
I have a 60' lg..flat screen..walked in house.heard lighting in a distance.my daughter turned the tv on..then it shut off..think lighting hit it..any way to fix//
Always a good idea to have a "surge protector" between the wall outlet for electrical and the appliance plugged into it. A surge protector will prevent a surge that could damage your set. $10.
1helpful
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Tv will not turn on with remote or botton on side
the tv was on a surge protector line, what i notice that i had it plug in a cheap surge protector when i pull from wall i notice the adapter were burn and the cheap surge was burn at that time when i go to cut tv on i could hear a surge like sound. i tried to put it in another plug it wont come on, i open back of tv looking for fuse i could not find it or reset button can solve this problem i hit input button on side it still wont come on. i do not think there is any problem with picture it has something to do with power.
Power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
1helpful
2answers
Reset Surge Protector
You can fix it by doing this. but first you need to make sure you leave your house for at least 4 hours so you don't have to be hearing that frigging noise, IT CAN BE DONE! i fixed it.
my unit would start beeping as soon as I plug it in wall, and red light come on, the software is telling me the battery is unplugged
this is what i did in order.
1. unplug all cords, connected to the unit, and power cord to the wall.
2. hold the power button
3. still holding the power button, Connect it to wall. (red light would be on but no beep)
4. I watched TV for 6 hours, red light still flashing
5. disconnect from wall
6 connect back to wall
I heard the unit click one time and green light came on, is charging now....
4answers
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
