Connect an ethernet cable to your router from pc. open IE, type 192.168.0.1 , it will ask for a user name and password, once you enter your user name and password, it will pull up the DLINK software, GUI. where you can go to wireless settings and change it to secured network.
if you dont know your username and password, follow this steps:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin
, and there is no password.
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In . How do I reset my router back to the factory default settings?
(NOTE: To reach the configuration page of your D-Link router in Mac OS, you will need to use a Java compatible browser such as Firefox or Camino.)
(NOTE: Some routers have a "Captcha" graphical login option. This option can be disabled in the advanced options of the routers configuration.)
