Saeco Incanto Rapid Steam - the shot of espresso is too hot and the coffee tastes burnt. Is there a way for me a user (not a technician) to adjust the temp? Is it a variable screw inside the machine? If so where is it located? Thanks Julian
Dear Jon,
Hi this shrikant from mumbai.This problem is happen due to dust stuck in tea/hot water valve ( for steam which you rotate).
If you have screw driver set then open the machine by using + screw drive. step below,
1.I here attach picture of valve.
2.you have to open it and clean it ( sea in pic 44,46,47,54).
3.after water leaking stop you have replace one o-ring 54 no. in picture.
4.After you machine work fine.
regards,
Shrikant Shinde
Yogishri Engineering
+91-8425830001
Either hte grind is not set correctly, the burrs are dull, espresso is being brewed in a cold cup, or the coffee is a little stale and the brew unit needs to be degreased.
zdravo,jesi li probao sa ciscenjem aparata,mozda masina trazi ciscenje sa specijalnom tecnoscu.naspi 0.75 l. tecnosti ili zavaraj masinu sa vodom otvori ventil pare i pritisni dugme za ciscenje i drzi nekoliko sekundi i onda bi trebalo da pocne sa ciscenjem,ovakav problem se obicno javlja kad masina treba ciscenje.
The leak is most likely from the steam valve, you will have to either buy and replace the o-rings and the pistons in the valve or just buy a new valve assembly and replace it. Easiest solution get the new valve assembly.
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact
Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : [email protected]
