Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Plug in unit so power is on, take key off, hold down speed + and stop keys on console, replace key, release buttons, press stop once, press and hold speed up until it reaches max, unit should run and speed up to max, console should read out max speed (s9.80 should read 11.8 - 12.5). It took me a couple of times to get this calibration to work. If unit does not run after several attempts then console is probably bad and will need to be replaced ($410) - get another treadmill ! If unit does run it may still beep - problem is with the IFit card, you can get rid of the beeps by opening console (unplug first) and removing the cable that connects the IFit card to the mother board. Of course IFit won't work but it won't be beeping ! Good luck
