Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Posted on Jul 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta 250 Bizhub scanning Operations
I cannot figure out how to specify the destination folders or emails for scanned documents
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you have IP Scanner installed into the computer that are networked to you copier?
Anonymous
Level 1:
  • Contributor 6 Answers
  • Posted on Aug 09, 2008
Anonymous
Contributor
Level 1:
Answers
6
Questions
Helped
20903
Points
23
What u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on Aug 05, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
Helped
198016
Points
292
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
2helpful
How to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
1helpful
Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Konica minolta bizhub 250 I need to scan many documents to computer says user id and password incorrect
the user name and password have to match the pc. if the pc does not have administrative rights the scan will be rejected most network security software will cause a scan to be rejected also
2helpful
How do you scan to PDF on a Konica Minolta Bizhub 353?
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Bizhub 250 error EA3226
Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address2.gif of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP2.gif settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings2.gif on the
computer are not specified
correctly.
Check the TCP/IP settings on the computer.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
2helpful
Bizhub C250 How to set scan to multi page TIFF for everyone. How to scan front and back of documents Thanks
To set scan default:
Select Scan Mode
Press Scan Settings
Press File Type
Press TIFF
Press Multipage
Press Ok
Press Utility/Counter
Press User Setting
Press Initial Setting
Press Current Setting
Press Ok
Press Reset
This will only affect address book destinations. Program destinations specify within their settings the file type.
To scan front and back:
Select Scan Mode
Select Destination (must be done 1st!)
Press Scan Settings
Press Simplex Duplex
Press 2 Sided
Press Ok
Weird scan problem with Konica Minolta Bizhub C351
It sounds like you have setup a fax forward box.
You need to set up a one touch, scan to SMB.
this can be easily done via your web browser by typing in the IP address of the MFP and set it from there.
You need the IP address of the laptop and is best to put the shared folder in the main drive (C).
Then for the file path you just need to enter the name of the shared folder EXACTLY as it is on the lap top.
You also MUST enter the ID a password to give it access.
2helpful
2answers
Konica Minolta Bizhub Copier/Printer How to Scan
When specifying the destination you need to complete the address to include the folder. Just like specifying a path manually, the server/folder.
You need add the folder as part of the server path.
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
