Sanyo DVW-5000 DVD Player/VCR Logo
Anonymous Posted on Feb 06, 2011
Lost my manual I need to hook up to my cabel box. plus what cabels i need for my dvw5000
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Feb 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
1167
Points
33
Here is a basic diagram of cable connection from a cable box to a vcr and to the tv.lost my manual I need - diagrams_hookup_tv_dvd_cabl.jpg
  • Anonymous Feb 06, 2011
    BASIC CABLE SETUP
Need both cabels for foor controle and one cabel end connector
need make and model of vehicle, year of manufacture also a plus. Best bet is to take the requested information to your local used parts dealer.
Aspect hitachi 65m200
You should have one or two antenna inputs. Select one and make sure the TV is set to that antenna input, usually, Ant A & B
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )
you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
Hooking up cabel box and dvd
Follow the instructions and pictures in the manual OR if cable the company will usually come out and hook it up.
1helpful
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Yard Machines by MTD..Riding lawnmower starter draws energy from battery but doesn't turn. Never replaced a starter. Don't know for sure where it is and what's involved.
ITS NOT HARD UN HOOK THE BATT CABLE THEN RE MOVE THE CABEL FROM THE STARTER REMOVE THE 2 BOLTS THAT HOLD IT ON PUT THE NEW ONE ON HOOK UP THE CABELS AND TRY IT LET ME KNOW IF THIS HELPS
Oct 07, 2009 • Garden
Pyle pla2170
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
DTV not working
YOU HAVE SOME LOOSE CONNECTIONS ON THE BACK PANEL OR IN THE MAIN A/V BOARD ASSY,YOU NEED TO OPEN THE TV AND LOOK FOR THE INSIDE OF THE JACK BOARD AND THE BOTTOM OF THE MAIN A/V BOARD
GOOD LUCK
[email protected]
2answers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
