Craftsman 1/2" Impact Wrench Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Question there are four settings on the air impact wrench 119106 I need to set to specific foot pounds are each of the four setting equal to a specific foot pound per inch (ie: setting one is 50 pounds and setting two is 100 pounds) thanks
Steve Hurc
Level 3:
  • Master 459 Answers
  • Posted on Feb 06, 2011
Steve Hurc
Master
Level 3:
Answers
459
Questions
Helped
352313
Points
1271
If you dont use hand tools often you should never trust the torque from impact wrench you should always recheck with tension wrench for correct torque specs
or at least hand tools such as breaker bar, spanner, ratchet
depending on what your doing up and diameter of bolt or studd for what application
2answers
I have a 99 R1, and I am installing a flywheel. It needs to be torqued to 9.5lbs. If it's tightened with a socket wrench is the 9.5 lbs achievable?
Use an Inch pound torque wrench (very cheap to buy), then set it to the conversion of 9.5 ft pounds to inch pounds which is 114 inch pounds.
1997 Dodge p.u. 2500 4x4 with auto locking hubs. What is the procedure for tightening the axle on hub nut, as this is also tightening wheel bearing?
I use an impact gun. But I believe the torque is around 75 foot pounds. You will have to use a pry bar and torque wrench to get the right settings.
1helpful
Dealership says to tork cham bolts to 89 in per pound.two bolts snapped, bought 2 new ones still happened
89 inch pounds is equal to 7.5 foot pounds. Check you torque wrench settings.
Torque setting in foot pounds for the rockers
8.8 ft lbs. use your calculator. 106 divided by 12 Foot/ Pound Torque wrenches are not accurate that low, thats why its inch lbs.
2helpful
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
1984 F 150: what is the torque setting 300 head...
70-75 foot pounds. Final torque must be reached in 3 equal steps, torque each to 25 foot pounds then 50 foot pounds, then 75 foot pounds. Recheck final torque in sequence.
How do I remove the primary to get to my primary shift lever on a 2005 harley super glide
This is a major job. Far too much information for this forum. It will require a lot of typing in this small space.
First, you'll need a few tools that you may or may not have. You'll need an air impact wrench capable of breaking a nut with 165 foot pounds of torque and red locktite on it. Next you'll need a torque wrench capable of putting 150-165 foot pounds of torque on the nut. You'll also need a torque that will torque to 60-80 foot pounds LEFT HANDED. Not all torque wrenches will torque left handed threaded fasteners. If you have these or can get them, Please drop me a line at [email protected] I'll type out instructions step by step.
1helpful
3answers
The 734 cp impact wrench has not been used for a couple of years and appears in excellent considtion however, I do not remember how to oil and/or remember the impact ratings using the dial; is there a...
Put 4 or 5 drops of oil into the air line opening. Connect an air supply and burst the trigger a few times. The settings are 1-less 4 more. It's all up to the application and they are not specific settings.
2answers
Need torque settings for 99 dodge durango head bolts & intake bo
Here's a link to a conversion calculator,www.unitconversion.org/energy/inch-pounds-to-foot-pounds-conversion.html
Top Craftsman Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve Sweetleaf
Steve Sweetleaf
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
