There should be a button on the narrow edge on the right side of the TV labelled INPUT. Press this button once to bring up the input menu on the TV screen, you should then be able to highlight the input from this list using the CHANNEL UP/DOWN buttons on the side of the TV. It may actually be the VOL +/- buttons to move up and down the list - I can't honestly remember so you may need to try a couple of times to get it right.
Finally I think you need to press the INPUT button again to select the highlighted input
It's best to switch the external input device on before doing this so there is a signal to the TV. It's easier to see when you have selected the correct input this way.
If you still can't select the correct input, please let me know and I will check on the exact method for switching this TV without the remote. I'm working from memory here!
Hope this helps.
Regards,
BElectric.
It's just saying no signal
