Re: All of a sudden I can not get the power to turn on
Try unplugging the power from the back and moving the cable to a completely seperate part of the house, and plug it back in. IF this doesnt work, the wii is broken.
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
1) test the outlet wall plug a desk lamp for to see if word, if does goto 1a) test the power cord 2) test the main switch for open or defective 3)go to the power supply see if the blown fuse replace or c.breaker reset. 4) if the problem persist, see for short in diode, transformer, filter, coil,rectifier.see the block diagram God bless you
My ecoquest fresh air turned off suddenly... when i turn it on again there is no power it keeps flashing in the front screen .. is it an easy fix or hard fix ? please advice ... thank you
Hi guest, if your computer turns off suddenly, try these steps:
Turn off your pc, remove the cables on the battery, remove the battery on the pc. Then push the power button for 5 seconds and then reinsert the battery and the cables. Then turn off the pc.
If symptoms persist , please call your technical support of the brand you brought for possible repair.
Problem sounds like the power supply pcb if the tv is totally dead with no standby light. However, first check that the main plug fuse is not faulty by replacing it ro checking with a multimeter
It may be because of a virus causing your system turn off suddenly. If you are sure that your system is free from Virus, then it may be because of processor over heating. If the processor heat reaches maximum limit, it shuts off the system automatically to prevent physical damage like burning, etc,. So, check weather your lappy's vent fan is working properly or not and clean if there are any obstacles like dust which are causing your processor over heating. Get back to me if this doesn't help...
Thanks
