Question about Razor E100 Electric Scooters Red
E100 Razor-no room to put air hose on the front tire air valve to fill with air
I had this same issue with the Razor E100. I couldn't even remove the plastic cap it was so recessed. Here's what worked. The value comes from the factory very recessed in. It's so far in it's hard to remove the cap with your fingers. You'll need to get the value loosened up and pushed out a bit. You will do this from the other side of front wheel using the hole. The value can be manipulated slowly to stick out about an inch from the plastic wheel. It takes some time and patience. First, you’ll need to turn the scooter over and rest it on the handle bars and back of the deck. Put a towel or flatten box under it if working on a rough surface to protect the scooter. Then used the supplied Allen wrench or similar object by putting the long end of the wrench into thru the opening hole on the other side of the wheel. Wedge the edge/end of the wrench against the value from the other side of the wheel and push hard to loosen up the value. This takes some time. Do this on both sides of the value and also against the center of the value. It took me about 5 mins of careful pushing. Eventually you will be about the get the value to almost a right angle from the wheel and sticking out about and inch. Then remove the plastic cap. This will give you room to attach a bike pump. I actually had to push the value back in a bit once finished so the wheel could turn freely. It will work, just be patient and forceful. Take your time.
Posted on Nov 03, 2018
3 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Why is my razor e100 red electric scooter going so slow?
Your scooter is dying the slow death that all Razor scooter owners are suffering. See my related post on this. Anyway, here's the deal..
I HAVE THE SOLUTION!! No, it's not what you're going to want to hear, but I have it nonetheless. The cheapest and easiest way you're going to fix this issue is by firmly grabbing the scooter, hoisting it directly upwards, clearing the rim and depositing it into your nearest refuse container. This is junk at its finest, brought to you from the worst in value and service, the Razor Company.
I did a little investigation into this problem as I too experienced what everyone that owns a Razor scooter does; it works for about two months, then suddenly the "battery stops holding a charge". You can Google Razor scooter issues and get page after page of this happening, along with more pages of frustrated people learning Razor won't do anything about it. But I digress.. back to the facts..
I need not repeat what I've already posted with regard to the issues surrounding my scooter, purchased Dec. '08 as a Christmas gift and not ridden (midwest snow) until the last month or two tops. So as I posted previously, it stops working and I'm assuming it's the batteries. I call my local Batteries Plus store and they say they can help. Here's where it gets interesting.
I bring in the entire scooter and charger. Let me say that I found the charger included in with my scooter.. "interesting?".. as directly underneath the red/green lights there are Chinese characters instead of English words, thus I never had any idea what these lights indicated. That notwithstanding, the test the charger on the spot and tell me it's working and is (pay attention here) 41 volts of charge. This means nothing to me at the time. I learn that testing the batteries in the scooter will take a couple days and they say they'll call with the results.
Before leaving, one of the CSR's engages me in a conversation about his identical experience with the Razor scooter he got for his kids one year prior. The circumstances mirrored everyone elses: it worked for 2 months, stopped working, he checks the batteries, replaces them, still doesn't work, he pitches it. Hearing this isn't making me feel any better.
So the weekend passes and here on Monday I get the call from Steve at Batteries Plus. Here's what he finds: There are 2 batteries in the scooter; one is at 60% of its life (this after a mere month of use) and the other is overcharged and 'swollen'. How can this be I wonder? I followed the charging instructions provided with my scooter TO THE LETTER, never leaving it charged for an extended period, etc. Well the answer is simple- the batteries for this scooter are 24 VOLT BATTERIES being charged by a charger that is outputting 41 VOLTS!! ALMOST DOUBLE THE VOLTAGE! It's overcharging the batteries and frying them out.
Steve said he removed and replaced the batteries with 2 brand new fully charged 24 volt batteries and it still didn't work. He surmised the switch that activates the motor, which is run through the charging system, was fried during its last overcharging.
Ergo, the charger included with these scooters is frying the scooters out in a very short period of time. To replace the charger, both batteries, and the switch would be more expensive than just pitching it and buying another brand new one.
This issie is Razor's fault and they should be willing to fix the issues (cue laugh track here). Go to their site and be ready to laugh at yourself for even bothering. Here's what I found. First I click the 'service/repair' tab, then am directed to the 'Razor Service Center Locater' to find the nearest service center to me to have it repaired. I entered my zip code and it said 'Sorry, no results found'. I then try my city/state, and again get 'Sorry, no results found'. Not looking good.
I then begin reading their return policy. It has a warranty that's good for 90 days from the DATE OF PURCHASE. Naturally, in my case I bought it in Dec. but since there was snow on the ground it was useless until spring; I was screwed before it even was given it's first charge. However, for the regular customer they'll find that even so, it's right at about the 2nd/3rd month when this thing takes it's final ride and as such, and through no fault of your own, your're totally screwed.
There are enough complaints on this scooter on the web that at minimum contacting the BBB is in order, and might I suggest a potential class-action lawsuit? This scooter retails still at $149, and like most of you I don't have $149 to throw in the trash every couple of months only to go and repurchase another "disposable" scooter.
So there it is. Not only are the batteries being overcharged and shot, but collateral damage to the electrical system is being done which is frying the switch that engages the motor and other things. Have your charger checked at your local Battery Plus (no charge) and you'll see they are putting out a defective product, and based on several hits on the internet they are clearly aware of it and do not care.
Posted on May 11, 2009
  • 38 Answers
SOURCE: I need instructions on how to replace the rear
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Posted on Aug 18, 2010
ON a Teknique GT rear wheel drive, I have a low front tire and valve stem is too short to hook up air hose, there is no room to attach air hose. What can I do?
most parts stores have extensions that may solve the problem. tractor/trailer parts store would also be a place to look.
Jun 08, 2015 | Cars & Trucks
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
How to fix my razor scooter e100?
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
Aug 13, 2014 | Sport & Outdoor - Others
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
Where can i put air back in the air bags i was told you can go to the gas station and replace air wheres the air line
By the air pump assembly you have few hoses that are filling up all the air bags and also the air tank. Looking from the front of your vehicle the assembly for the air pump is a black box on your distant right in the back. The first hose on the box closest to you is filling the air tank (it is marked on the side of the box "6"), the second hose on the box is for the exhaust air (you should not worry about), the rest four of the hoses are for your wheel's bags. If you connect the splitters to them than you can fit the tire valves to them and fill it up with the air. The pressure should not exceed 70lb psi. Until you find the problem with the suspension, you can make the ride more comfy.If your Rover has blown hose, I would go to garage to find the spot, on mine it was well hidden under the body and between the rear differential. Hard to see and hard to diagnose. Good luck.
Jul 18, 2012 | 1999 Land Rover Range Rover
Razor e100 dead
Check the battery and charger with a multimeter and make sure that its putting out the required voltage or more, also inspect the batteries for bulging
Jun 07, 2012 | Razor E100 Electric Scooter
I am trying to figure out how to put air in a presta valve. The tire is just a little flat but we couldn't seem to fill it at the gas station. I think the bike may have been used when we bought it.
You can not fill a presta valve at a gas station because the valve is too small for the hose. The hose at a gas station is made to fit a schrader valve.
here just check out this video:
http://www.youtube.com/watch?v=9byRp9e2USU&feature=related
hope this helps.
Sep 23, 2011 | Bell Sports Bell Universal Bicycle Inner...
How do i use the schwinn airdriver 1100 pump
This pump is a bit strange to use. The valve in the filler head is odd in that it controls the flow of air in both direction...which is not a great design in my opinion...but it does allow for use in different filling applications. The trick is getting the pump into its different filling "modes"
For a Schrader bike valve:
1. Make sure the pump is in "tire mode" by blowing into the valve with your mouth. If you then pump the handle you should feel air filling your mouth.
2. Put the "locking lever" in the unlocked position, the unlocked position is when the silver metal lever is parallel to the air hose, or said another way it makes an "L" with the air outlet that goes on the tire air filling stem. To verify this is correct, look in the air outlet and move the lever from locked to un-locked, you will see slight change in the diameter of the outlet.
3. Push the air filler hole over the schrader valve really hard and make sure it is seated all the way down. Close the "locking lever" (silver metal lever should now be perpendicular to the air house and be in line with the air outlet... i.e. point straight out away from the tire filler stem.
4. Pump.
For a Presta bike valve:
1. Make sure the pump is in "tire mode" again.
2. Take off plastic caps off presta valves on bike tire.
3. Unscrew the little nut on the presta stem to allow the tire valve to open when pressure is applied (you can test this by pushing the stem in a little and air should escape, the nut holds the valve closed, so it needs to be loosened).
4. Take the adapter from the locking lever (silver metal lever) on the pump and screw it on the presta valve. The adapter is the brass looking thing. Screw the rubber gasketed side down on the presta valve.
5. Press the air pump tire filler outlet onto the adapter.
6. Close the locking lever to seal the filler head on the adapter.
7. Pump.
8. Unlock the locking lever and pull it off quickly.
9. Unscrew the presta adapter and screw down the presta valve nut but just finger tight.
10. Screw on the plastic cover cap for the presta valve.
To Fill a Ball:
1. Twist the ball pin filler out by rotating the gray plastic tab around until the ball pin filler is pointing straight out (in-line with the air hose).
2. Make sure the pump is in "Ball mode" by again blowing into the filler. Sometimes shaking the filler valve really hard is necessary.
3. Put the filler pin into a ball.
4. Pump.
Hope this helps.
Apr 27, 2011 | Schwinn Cycling
I need instructions on how to replace the rear tire on a razor electric scooter model E100
Jul 27, 2010 | Razor E100 Electric Scooter
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
Razor E100 Electric Scooters Red Logo
1,851 people viewed this question
Top Razor Sport & Outdoor - Others Experts
WTF Chuck.....
WTF Chuck.....
rigger094
Kenny Tullis
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
