Question about Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX)
I have a Netopia modem and when I connect an AT&T Microcell to it, our network printer no longer receives print jobs. They just pile up in the queue. AT&T directed me to a support page that had some settings to change, but Netopia doesn't have the same settings so I can't make any changes. Does anybody have any ideas as to how to prevent the Microcell from interfering with network printing? Thank you.
3 Suggested Answers
SOURCE:
  • 32 Answers
SOURCE: can't approach router to change channel/security
go to your network status on your computer and see what your default gateway address is, that should be the address of your router.
Posted on May 10, 2009
  • 1566 Answers
SOURCE: I have 2247 NWR-EIR wirelss modem. I have bought
Hi Larisa,
What particularly in the MTU settings needs to be changed?
Can you post the exact message it is giving you?
Thank you,
Lyzmorato
Fixya Premium Expert
Posted on Nov 09, 2009
Got my HP laser jet P1005 plugged into 1 PC prints fine. But 2nd PC is networked to it and it takes ages to print! How can I speed up send PC print job? Both PCs Only ever print single pages.
Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
Feb 19, 2016 | HP Office Equipment & Supplies
How do I fix error cf 248 for my Kyocera 1128. I have tried several times shutting off. Taking out toner and checking paper jam
If its what I think it is, then the error occurs when your machine is receiving a corrupted print job. This is shown by the data light flashing for several minutes before showing the error.
If this is the case, then unplug the network cable from the machine, power the machine off & on & wait until it comes ready. If the machine comes ready then try a photocopy. If that works then it is a corrupt print job. Before plugging the network cable back in, check any PC's that print to the copier & check the print queues to see if any PC's are still spooling a print job. If so, delete the print job & re-connect the network cable & test the machine.
I have found most corrupt print jobs will be from the internet & will have "www......" listed as the print directory list.
Hope this helps.
Dave.
Feb 13, 2016 | Kyocera Office Equipment & Supplies
Looses connection with network
Common for this printer. Instead of setting it up as a network printer, attach it locally to a machine and share it. It will be much more stable.
Aug 09, 2012 | Lexmark T620 Laser Printer
Samsung slp 770 incomplrte session by time out
The Samsung CLP 770 produces an 'incomplete session by time out' if you switch off the computer originating the print in the middle of the print job (before the print is finished) OR if the network connection is lost between the computer originating the print and the CLP 770.
The printer may have printed the start of the print job but also recognises that it has not received the end of the print job information. It waits for a good while for the connection to be restored in an attempt to receive the rest of the print job - but if nothing comes then it times out.
The reason for this action is to prevent this situation effectively locking out any other computer on the network from printing while it 'waits' for the end of the print job.
Dec 28, 2010 | Samsung CLP-770ND Laser Printer
The E light is on and my printing jobs are piling up..will not print
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
У меня HP Photosmart 3210
Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
  • Connectivity :
Oct 27, 2010 | HP Photosmart 3210 All-In-One InkJet...
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Oct 24, 2010 | Netopia 3-D Reach (TER/GUSB-N1)...
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
Jul 25, 2009 | Computers & Internet
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Jan 11, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Netopia (3347NWG-VGX) Wireless Router (3347NWGVGX) Logo
136 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
