It is normal for there to be a hiss from the pressure switch for a second when the unit stops, this allow any pressure in the line to be dissipated so next time the unit starts it doesn't have a pressure to start against. If it is constantly leaking it will be a problem with the non return valve. It is normally a brass fitting on the tank that the compressor pipe goes to. It may just have a bit of debris not allowing it to close properly, You need to drain down all air and remove the cap on the brass fitting, there should be a rubber shuttle with a spring behind, if it is hard an cracked it will need replacing or it may just need a clean.
Hope this helps,
James
SOURCE: Compressor is having trouble sustaining pressure. No leaks.
it has to be leaking some where check Liquid soap check the intake filter.
SOURCE: I have a Porter Cable
I believe you have a head valve or piston ring problem. The parts you replace are suppose to leak. It is a safety feature that doesn't allow the motor to burn up before the pump warms up. Kind of like a soft start feature. If you look on the breakdown part number 107 Kit Valve Plate is what you need to inspect. Sounds like your valve plate is either worn or damaged. If you go into the pump you will have to get part 103 also which is a gasket kit. Or you can try to salvage the old gaskets.
If the valve plate is ok you will need to inspect the rings that go around the pistons. Some times you will get one that gets brittle and breaks off scarring the cylinder. Look for these two things, I am pretty sure one of them is the problem with your compressor.
SOURCE: air leaks out of pressure
There could be one of two things going on here....
On many compressors the air is supossed to bleed off after it shuts down from the hose to the head toallow it to start easier... but I don't think that this is what is happening from what you are describing here...the checkvalve to that will get dirt in it sometimes...
Now if you are leaking at the pressure switch then the pressure switch is defective....they are easily replaced and can be purchased from www.grainger.com
heatman101
