Belkin (F5D7230-4) Router (587009) Logo
Posted on Feb 05, 2011
Hoe can i connect my ipone to wiifi on my belkin router
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Feb 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
4626
Points
51
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Belkin Router TeCh SuPpoRT pHoNe #{+1^84433O233O~} nUmBeR USA
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Belkin Router Customer SuPpoRT pHoNe @#{+1*84433O~233O~} nUmBeR USA
I had belkin g wifi router,i am not able to connect it to my internet,hoe to use this rourter.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Just purchased belkin play n600 and am having trouble with setup. Everything loaded, but I cannot access the Internet from my pc now, my iPhone and xbox can connect but the pc the router is connected to...
ok what you will have to do is go to control panel and unistall all the software for the belkin then you will have to reinstall the software when you install make sure you only hook up the router to the computer and get it to work then you can hook up the xbox and the ipone you will have to set up port forwerding for the xbox to work correctly.
B52computers
Chris Thrash
I have installed a Belkin wireless router $I have a new TV with wiifi capabilities. It is asking for Access point name, what is this.
1. 1. Login to router first and verify that the router with the rj45 cable.
2. go to the "wireless setting" see what the broadcast name is.
My F5D7234 is not working w/ Windows 7. Watsup?
Is your modem connected to the main computer or the router ?
If the main computer is connected to the computer then you will need to connect the modem to the router .
Check the connections.
check the settings on the router.
I hoe the following link will help you.
Click Here for more info
I have a Belkin router and i don't know hoe to cennect my laptop to my main broadband at home ,what do i do with the yelow cable do i connect the router to my laptop ? I have no clue and it;s really...
Here's how to connect the router.
From your broadban modem, connect the ethernet cable to the Internet/WAN port of the router. Then using another ethernet cable, connect your laptop to port 1 on the back of the router. Now run the setup CD that came with your router. After setting it up, it will tell you to disconnect the ethernet cable from your laptop to try the wireless function. Good Luck!
3helpful
2answers
Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Encryption problems
You just have to enter the WEP encryption that you have configured on the Belkin router to reconnect your laptop back to the wireless router. To verify the WEP of the router:
  • Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  • You will get a login page. Leave the password blank. Click Submit .
  • On the left side of the page, click Wireless Security or Security below Wireless .
  • Take note of the WEP key.
  • Click Logout in the top right hand corner.
  • Not finding what you are looking for?
    Top Belkin Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    Alexander
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
