Baldor 1022w 10" Bench Grinder, 1 Hp, Single Phase -new Logo
Posted on Jun 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone know the part number (or better) the spec for the cap? I don't mind buying from Baldor but would prefer to buy the cap locally. since the cap was removed before I got the grinder, a link to a hookup guide or wiring schematic would be great too. Thanks,
Pieter Vleeshouwers
Level 3:
  • Baldor Master 2,029 Answers
  • Posted on Jul 05, 2017
Pieter Vleeshouwers
Baldor Master
Level 3:
Answers
2029
Questions
0
Helped
4113767
Points
7389
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
1helpful
What type and size capacitor goes on a Baldor 1/3 HP bench grinder
Much would depend on whether it is a start capacitor or a start/run capacitor.
If there is a switch on the end of the rotor operated by centrifugal weights it will be a start capacitor only but if there is no centrifugal switch the capacitor will need to do double-duty and the value could be critical.
Contacting a dealer or the manufacturer would be favourite but a motor specialist might be able to make a recommendation. Guessing isn't really an option and the working voltage of the capacitor is equally important. Most generic capacitors are rated in dc volts and for them to be safe used on ac mains the working voltage must be considerably higher than the rms value of the ac mains. It is best to use only capacitors rated for ac mains.
You will probably find the capacitor as a spare part from a dealer will be prohibitively expensive but once the value has been discovered and if possible the manufacturer, part number and so forth, great savings can be made by sourcing direct from the capacitor manufacturer.
I recently paid less than £5 plus carriage plus VAT for a capacitor the machine manufacturer wanted more then £60 for.
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
1helpful
2answers
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
I NEED THE SPECS ON THE CAPACITOR FOR A 9520 6" BENCH GRINDER
remove the cap cover on the motor and its on the side of the cap i.e. mfd/v.a.c.
Mar 19, 2010 • Grinders
1helpful
Wheel guards on mod#662R screws missing. Need to know what size to replace with.
near as I can figure they should be a 10-32 x 3/8 serated bolt. the website doesn't define the parts that well
Unit has rt & lft threaded tapered (point) shafts & seems to have ability to ''chuck'' bits.---this is my first encounter w/ this system and to my dismay and chagrin i can't use it --have all specs...
Some grinders have tapered, threaded shafts that allow the use of soft buffing or metal polishing wheels, could that also apply to yours?
1helpful
Grinder starts and stops on startup
if this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Top Baldor Grinders Experts
Oliver Street
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Baldor Grinder Expert? Answer questions, earn points and help others
