HP OfficeJet 7410 All-In-One InkJet Printer Logo
Posted on Feb 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All lights flashing and is saying error 0x07a74dd6 on top of the screen then half way down it is saying 1659 lib_barracuda.c
Level 3:
  • HP Master 7,733 Answers
  • Posted on Feb 05, 2011
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1863786
Points
21487
How to Fix HP Printer Error Code 0x07a74dd6 ?
Usually, Error Code 0x07a74dd6 occurs when users try to start printing via connection to the computer. The Error Code 0x07a74dd6 could refer to anything from the product needing a basic reset to reinstalling the printhead or cartridges.
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
9helpful
3answers
Apps lib was not working properly it keeps saying check conection i have formatted the device then updated to the newest opperating software i have re downloaded apps lib and it says its installed but it...
Same here, come on archos at least post an aknowledgement on appslib! Day 4 of owning the device, don't let me down after choosing *you*.
Archos 101 user
2helpful
I have a G shock 1659 model, kinda old, but I
Press Adjust / Hit Mode until the minutes or hours is flashing. either one will do. When on or the other is flashing press the "G" button for the light. This becomes the switch for 24hr/12hr.
1helpful
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
How do i put my camera in the still frame mode?
follow this link to your manual
http://lib.store.yahoo.net/lib/starbattery/DC100.pdf
1 open cover and move slider down to C
2 press the stop start half way
once auto focus is adjusted O will turn green and 1 or seveal af frame will apear.
3 press start stop fully
the DISC access indicator will flash as image is being recorded.
1helpful
2helpful
3answers
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
Mits WD 52525 format issue.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
k24674
Grand Canyon Tech
Grand Canyon Tech
