SOURCE: Arris Modem connected to Mediacom Service
I didn't have incoming calls for a year (didn't mind, no telemarketers). But I fixed today.
Check with your home alarm company. Turns out they can download a signal. No, it wasn't the computer's internal modem, it wasn't the phone/cable company or the arris modem.
No need for service call.
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
