MMS setting required for using MMS service (GPRS stetting and MMS setting is different).
To get the MMS setting please call your service provider.
They will send you the MMS setting.After you receive please save the settings to your
phone.
Then you can start send and receive MMS without ant problem.
Good Luck.
Thanks for using FixYa.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
Setup/Enable GPRS
Select Sun GPRS
APN: "wap"
Select SUN MMS
APN: "mms"
Setup/Enable MMS
Proxy Port: "8080"
Setup/Enable WAP
Proxy Port: "8080"
