Try to get to the technician or search your replacement screen here: Amazon com Online Shopping for Electronics Apparel Computers Books DVDs...
SOURCE: Nokia 3230 Screen malfunctioning. Phone still works. Just need a few tips from you guys.
why you make it hard for you.. only you need to replecd the lcd ... buy a lcd and even you can replaced it by your self.. it got only two screws on the top and same in the lower part..
SOURCE: nokia 6085 has a blue screen
^ WTF. That totally made no sense.
The nokia display on your phone is pressed onto metal contacts, as opposed to soldered like Siemens does. This results in a temporary/permanent loss of connection; bring the phone to a service center for your carrier, otherwise your out of luck.
take the phone to a mobile service center and have the LCD replaced on the phone.
SOURCE: Screen Not Displaying. But Can Still Make Calls.
you need to change your lcd or if you want to try to fix it yourself just open your phone take it apart and then tighten up the connections to your lcd to the main board of your phone...
i have repaired this problem time after time you need to replace the flexcable which is located inside the phone between the top and bottom of the phone the problem is that these phones are very poorly made and the cable inside gets crunched up with opening and shuting of the phone its very easy to replace and change and with ebay you can find the cable for around 4 pounds inc postage if you need help opening the phone please email [email protected] i have had around 10 of these phones to fix and only 1 out of the 10 the screen needed replacing change the cable first its cheapest option! hope this helps all!
