I seriously doubt the computer would left click by itself. I have worked on computers since the 70's and have not seen it. There could be two or more reasons for the left clicking. First, and mostly, I would suspect the mouse. I would get a wired mouse and see if it stops. If not, then I would check the keyboard. Some keyboards have mouse controls, and a key could be "sticky". By the way, if you have the original paperwork for the phone, I bet it would say "may cause interference with other electronic devices".
SOURCE: Logitech wireless mouse and keyboard
Normal
0
Press the Receiver button (and the lights will start
flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT
button on the back of the board to connect the keyboard to the
receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button
on the back of the mouse to connect to the receiver. Then they
should work okay.
Hope this helps. Bud
SOURCE: left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
Normal
0
flashing.
receiver.
should work okay.
SOURCE: Erratic Logitech cordless optical mouse
ive had the mx700 for two years and im very comfortable with it.
I think you problem lies not with the mouse or the driver, but rather the mousepad.
Since the mx700 is not a lasermouse, but "only" optical, it still needs a decent pad to work flawlessly.
Ive had problems with these kind of mice using blank paper, magazines or tablesurfaces.
Try to get a real mousepad from somewhere (should be really cheap), that should do the trick =)
I upgradet to a razer diamondback later which is a laser mouse (1600dpi, while optical mice (with the red light) have 800dpi). Some ppl say that this is too much, and not needed (you can get even higher specs =) but i felt a world of difference, it just works everywhere! (except for mirrors and glas =)
SOURCE: problem with LOGITECH S 510 cordless keyboard and mouse..
I have this same keyboard/mouse set and love/hate it when the batteries die. After you change the batteies, power on your pc, press & hold the connect button on the bottem of the keyboard first and then the connect button on the transmitter. Release them and wait for a few seconds. Repeat the same steps for the mouse.
When I have connection issue with this keyboard after new batteries, I have found most of the time the problem is the connection to the pc and/or batteries in wrong. Good Luck
C2Solutions
