HP LaserJet P4014n Printer Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need specific HP P4014n printer cartridge ITEM No. for reordering purposes.
Buddy Mcsparrin
Level 3:
  • HP Master 1,684 Answers
  • Posted on Feb 04, 2011
Buddy Mcsparrin
HP Master
Level 3:
Answers
1684
Questions
Helped
1011521
Points
4641
The toner number you need is CC364AX for high yield or CC364A for standard. The high yield has more toner so it will last much longer.
I hope this helps, if so please rate our solution.
BuddyMc
Red flashing light still on even after replacing p4014n catridge
Could be a paper jam inside the machine(pick up: between the tray and cartridge compartment or EXIT: Between fuser and EXIT UNIT.
ALSO could be BAD SEPARATION ROLLER IN THE PAPER CASSETTE TRAY and UPPER SEPARATION ROLLER OR BROKEN FUSER. Question? call 917-359-7432
Hp laserjet p4014 says install black cartridge while cartidge is in there. Tried with different cartridges which work on other 4014 printers but no change. The problem is in the printer not in the...
For some reason it is not reading the memory chip on the cartridge. You can run your finger over the reader which is located top right inside after removing the cartridge just to make sure it is clean. I have never had to replace the reader ever, but the cartridges many times.
My Hp Laserjet P4014n is giving error 57.07 after I repaired the power board
It means that the laser beam of your printer is not detected.
Try to change the printer toner.
***If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
1helpful
HP P4014n LaserJet Printer Close top cover won't close
the most common problem that causes the top cover not to close is the toner cartridge not being seated. Pull it out and reseat it.
Why did you open the cover in the 1st place. If it was to install a new cartridge, try putting the old one back in. If it works, the replacement has a problem.
If the cover doesn't close with the toner cartridge removed, then there probably is a linkage problem. Something may be broken, like the "print cartridge drive arm".
Go out to www.hp.com.
My hp laserjet p4014n prints with black background but the words are readable
This is mostly caused by inferior toner cartridges ( non genuine ). Have you tried a genuine toner cartridge?
I unplugged my HP P4014n printer to spray some
Check the main fuses on main board, check lithium battery,...
HP laserjet p4014n "Load BOnd paper in tray 1" issue. A couple of weeks ago all the P4014n printers on our network started getting out 0f paper messages on our 2003 servers. The users have to push the...
Check the media settings for your paper trays. Make sure they are set properly, also check the diver media settings. Is the problem happening with a specific print job? If it is check the page setup for that document.
k24674
Grand Canyon Tech
Grand Canyon Tech
