Expert
- Posted on Feb 04, 2011
Re: How to replace the top rollers on a GE dishwasher...
Lower Rack
- Remove all of the dishes from the lower dishwasher rack.
- Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
- Lift the lower rack up and out of the dishwasher.
- Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
- Upper Rack
- Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
- Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
- Pull the upper dishwasher rack straight of out the arms to remove.
- Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
- Align the end caps with the ends of the arms, then push the end caps into place.
