ASUS P5GPL-X SE Motherboard Logo
Posted on Jul 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mboard have 4 slot of RAM DDR, but i can't put all my RAM on all (4) slot, only 3 slot my comp can read (my RAM is DDR 512 MB pc3200 x 4) soo.. i have 1 Free DDR 512 and 1 slot.. please..please guide me, what should i do..?? i wanna maximum Memory RAM 2GB in my comp. my mother board is intel ASUS P5GPL, chipset model i195P/i195G, version 0901, southbridge model 82801FB (ICH6). Please Help me??! thanks a lot..
Donna Sander
Level 2:
  • Expert 277 Answers
  • Posted on Aug 02, 2017
Donna Sander
Expert
Level 2:
Answers
277
Questions
5
Helped
89667
Points
708
Looks like you have the right kind...they have to match you know...you could try 2/1g sticks instead...
Your compatible memory is here: http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/p5gpl-x
4 Related Answers
Anonymous
  • 2351 Answers
  • Posted on Feb 23, 2008
SOURCE: MOTHERBOARD SOUTHBRIDGE CHIPSET PROBLEM
You can add a heat sink to the Southbridge chip as listed at this link:
http://www.frozencpu.com/cat/l2/g33/c173/list/p1/Ultra_Quiet-Chipset_Coolers.html
Microcool Chipsink Southbridge Passive Heatsink
The word passive means no need for screws or clamps. A special teflon tape sticks to the chipset. If you feel this may not be enough you can always add a side case fan that will direct air flow right on the Southbridge chip & also feed fresh air to the whole board. http://www.xoxide.com/80mmfans.html There are tons of cooling here & more passive coolers as well for both Northbridge & Southbridge.
I'm sure this will make a difference.
please vote...
colliewob
David
  • 781 Answers
  • Posted on Oct 14, 2008
SOURCE: Audio Device intagrated in Asus Mother Board
Try downloading Microsoft UAA drivers and install first
Uninstall your sound driver install UAA drivers then install sound drivers
Anonymous
  • Posted on Nov 04, 2008
SOURCE: ASUS P5GPL and 4 modules DDR-400 512 Mb Hynix - not work correctly
I CAN NOT LOAD WINDOWS XP IS THERE BIOS PROBLEM ?
MY MOTHER BOAD IS 815E ( P 3 )
WIN 98 EASILY WORKING BUT NOT WIN XP
Anonymous
  • 341 Answers
  • Posted on Nov 28, 2008
SOURCE: max. video card or controler
Get the AGP card with the most memory you can get.AGP is a pretty old architecture. You may need to hunt one up on ebay. Might try Newegg.com
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
RAM compatibility HELP
Yes this pc3200 is hardly compatible, because your motherboard is supportable of DDR 1 type RAM, Hence th PC3200 = 400 MHz, so you can add this ram to your PC, such that the ram which is between 266mhz to 400 MHz is absolutely a DDR1 type . please dont forget to vote for me.
Would A 1GB PC3200 run in the K7s5a alone.
According to the specs the max amount of ram is 1 GB and max speed is pc2100 so a pc3200 would not run on it unless the board was able to clock the speed down of that single stick of ram.
I was not able to find the max amount of ram per slot on a quick search but most likely it would be 512 mb per slot for a max of 1 GB between the two DDR slots.
at Newegg you can find DDR 266 1 GB kits (2 x 512mb) which would get you the 1 GB of ram.
Thankx for ur reply this is my ram config. i think it is compatible to each other. 512 MB DDR PC3200 128 MB DDR PC2700 Maximum Memory Capacity: 2097152 MB Currently Installed Memory: 640 MB Available...
I am glad to hear that your PC is running well. If you need any help again in the future we will be here. This is something we like to do, so there no having to tolerate at all. Only us helping you to understand your problem.
Nov 12, 2009 • Baby Gear
1helpful
2answers
I have installed 1 GB + 512 MB DDR II RAM, but it read only 1G I have just bought the Corsair 1GB RAM (DDR II 667 MHz, 6400), and installed it in the slot 1 of my motherboard, but it only read as 512 MB. (...
Nowadays, motherboards supports only a selected number of RAMs. You have to read the manual and select from the given models. I am not talking about DDR2 or 667MHz. The manual will state the manufacturer (ex. Kingston) model no (KVR667XXXXXX) etc. Only those stated in the manual will work correctly with your motherboard.
2helpful
2answers
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
2answers
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
1helpful
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
