477L Ask RXTX HHU Remote Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My car keeps on turning on by it's self and it does not have the timer set.
Larry Spears
Level 3:
  • Avital Master 625 Answers
  • Posted on Feb 05, 2011
Larry Spears
Avital Master
Level 3:
Answers
625
Questions
0
Helped
378107
Points
1510
If your remote starter is activating "by itself" and there is no timed start setting initiated; the activation wire (white with blue stripe) is touching ground under the dash. Locate the command module of the Avital unit and isolate the white with blue wire by applying some tape to it.
My tv keeps turning on by its self. At night I use the sleep timer a lot, but I do not know if that's why it turns on randomly?
Yes,tv it will turn on and off randomly,if sleeper timer mode is on,u probally setup for both OFF and ON setting same times like 30,60,120 mins setting is on.
How to take photos by keeping self timer
Just set the self-timer from MENU option, then you can take a picture. Just press capture button once and the timer will countdown automatically.
MY PHILIPS WIDESCREEN KEEPS TURNING ITS SELF OFF
CHEEK UR POWER SETTING AND SLEEP TIMER YOU WILL FIND THE SETTINGS IN UR MANUEL......MAKE SURE SLEEP TIMER IS SET TO OFF
1helpful
Cannot find the self-timer feature on the camera. help plz...
To turn on go to MENU / Drive mode / Self-timer.
To set delay time go to MENU / Setup / Screen 4 / Self-timer. Can set to either 2 or 10 seconds.
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
1helpful
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
2helpful
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Top Avital Vehicle Parts & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
