Ok check to see if your TV screen has a back light glow and use a flash light to shine it against the screen to see if there is an image. If there is no image then your T-con board is defective. The T-con board is the part of the tv where it gives you image/video partion of the TV. You should also check the HDMI source connections and all the AV connections in the back of the tv to see if its loose or no plug in properly. If all fails then have a tech come out and check the tv.
Check the power cable feeding the power to th PC
