Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
If the BIOS password cannot be remembered, the unit will need to be sent in for password removal. This service is not covered under warranty and charges will apply to have the password removed.
Please go to Fix My Acer and set the unit up for service requesting BIOS password removal. In the description please use the following: "Requesting BIOSpassword removal".
Note: This is for the BIOS password only and does not include the Windows login password. Acer does not remove Windows login passwords.
