Expert
- Posted on Feb 04, 2011
Re: I need to use this phone as a modem for internet....
- Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
- Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
- Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
- Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
- Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
