Toshiba Satellite C655-s5090 Notebook Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cleaning my fan on my toshiba satellite c655 i need to know how to take it apart to get to the fan
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Feb 04, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541595
Points
28391
There may be information on this site that will help you;
www.insidemylaptop.com
They specialise in photographing dissasembly of laptops and most Toshiba laptops are put together the same way, so I hope it helps you.
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
I have a toshiba satellite C655
some laptops will run with out battery and at some point replace it.
1helpful
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Toshiba c655 xp driver
Toshiba lists exactly 170 different C655 Satellite laptop models.
Find your exact Satellite C655 model number then check Toshiba downloads and support at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
1helpful
2answers
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
1helpful
Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely, Nathan Hicks
2answers
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
