Is there anyway that I can burn more than one song at a time onto a cd-rw using just the tascam 2488 original???I've only been able to burn just one song per cd..I want to put at least 12!
THANKS,
Paul
Although I was a factory authorized service center for Teac and Tascam, this is a much later product than I'm familiar with; no problem however.
If you have your owner's manual, the procedure will be listed there. If you no longer have the manual, just Google Teac, in Montebello, CA. I'm quite sure it will be our their website.
I had the same issue on my 2488neo. What I found that worked for me, was during the mixdown, make sure the solid levels on the right side of the mini screen are at the top of the black line, don't worry about it sounding too loud. After your mix down is done, pick a mastering tool that best fits your style of music, during this process any levels that go over peek will be eliminated. Once your mastering is done, burn a CD, but don't finalize the CD, so you can use it again to keep checking if the volume does not match that of a regular CD (a known band CD from the store) this worked for me, hopefully it will for you as well..
sounds like a software problem, dont know if there is an update possible, but you can try this:
take out the drive, connect it to a pc, copy all data from both partitions to your pc, format tascam driver to one partition and copy all music from pc back to drive ;)
this will definetily help, thou you dont have the problem reading two partitions.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Read page 75 of the Neo manual VERY CAREFULLY. I am quite sure you will find a solution to your problem there as I had the same thing happen to me once early on.
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
