Hello!
looks, like you having a problem with DMD module. It's the main part of light engine. That's where you want to look first. Quite possible, that DM could be at fault, as well. DMD is most expensive part, DM(digital module) is not that bad. That one deliver signal to DMD, light engine processor. due to high temperature inside of those little things, fauly surface mount electrolytic capacitors are to look for. It requires very high technician skills and couldn't be performed at home. I'd recommend to start looking for DM, first. E-bay, used parts distributors, etc. You could replace it with caution. Make sure not to break any ribbon cables or connectors, if you decide to do it yourself. Especially, when you pry covers to open, In many cases, ribbon or regular connector's cables(boards to control panel) could be very short. If you take top cabinet off rapidly, those could brake off. Anyway, I'd rather take it to reputable repair shop.Especially, with this kind of problem.
Good luck with your project,
Alex. c/o Alex's Television, Philadelphia PA.
