Computers & Internet Logo
Anonymous Posted on Feb 03, 2011
I plug in my dell computer and the brightness won't come up
Michael Galve
Level 3:
Genius:
  • Master 1,269 Answers
  • Posted on Feb 03, 2011
Michael Galve
Master
Level 3:
Genius:
Answers
1269
Questions
0
Helped
426690
Points
3247
For Desktop Computer:
There are simple things that you can try first. Check the Monitor if it is turned on. There should be a light indicator if it is on or off. Usually it is next to the power button. Verify if the power cord is plugged in. Check the Video cable connector if they are tightly connected on both ends (tower and monitor).
For Laptop:
Make sure the battery is charged. If not, plug the power charger and verify if its charging or not. If its charging, there might be a problem with your LCD. If its not charging, it could be a battery problem or charger problem.
1helpful
How to adjust contrast on dell 610
From this web site:
http://www.computerhope.com/issues/ch000594.htm
How do I adjust my brightness or contrast on my laptop? Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
Other examples also shown in the above picture include pressing Fn and F1 and F2 or F7 and F8 to increase and decrease the brightness. If none of the above examples resemble your keyboard look for keys on the keyboard that have pictures of a sun or a half moon to identify the correct key to adjust the brightness.
How can I adjust the laptop contrast? Laptops only allow users to adjust the brightness of their screen. Contrast settings are not adjustable on a laptop display.
How do I save the new adjusted settings? After adjusting your laptops brightness it will retain the new settings.
Laptop brightness is still not enough or screen is black If after following the above steps your brightness is still not enough, plug your laptop into the wall to make sure it is not a power setting that is decreasing the brightness. If the laptop is plugged in but still is not bright enough, try the suggestions on the below link.
How to brighten my screen on my computer
Locate and press the "-" button on the front of your monitor. This opens the Brightness/Contrast menu.
Press "+" button to scroll through the menu and press "-" to choose the Brightness control.
Press the "+" button to increase brightness and "-" to decrease brightness. The settings will automatically save.
Hope this helps
2answers
My dell D400 won't work when i plug it in to the wall outlet the screen goes black and you can't see anything unless you point it into the light a certain way. Any help or ways to fix this problem?
To Whom It May Concern,
I am very sorry you are experiencing this problem. I will be more than happy to assist you. The problem seems that you just have to adjust the Brightness.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
Hi. i have a problem with my lcd brightness in my win 7. i have dell 1520 since 3 days ago when i plugged in the charger, my lcd brightness goes to low. and when i unplug the charger everything will be...
just from the top of my head. But does your dell come with all kinds of dell management software installed ? Lenovo has this to, if you change the settings in control panel nothing works as it should because it's overridden by the companies management software. Check for dell software to manage your pc. Or go to control panel and see if any dell software is there. in that case, uninstall it and the control panel options should work. Bloatware...
DELL Inspiron 910 Netbook 9
Hi there!
Try to change the setting of the brightness in BIOS,
You can access bios by pressing f2 after you turn on the computer, then you will see brightness there, max out the brightness.
If it still does not work then go to the power options of your laptop then change the setting of the brightness when the charger is plugged in.
Hope this helps!
1helpful
I have Dell 1525 inspiron , earlier when u plug A/c power cable screen brightness will increase but now brightness is same power given or not(high(
PRESS fn AND UP ARROW KEY TO INCREASE THE BRIGHTNESS OF THE LAPTOP SCREEN.AND DOWN FOR REDUCING BRIGTNESS ALONG WITH fn KEY
YOU CAN CHANGE THE POWER SETTING TOO
WHICH FIXES THE BRIGHTNESS
WHEN IT IS ON BATTERY POWER OR IT IS IN A/C POWER.
FOR DETAILED SOLUTION PLEASE TELL ME YOUR OPERATING SYSTEM.
2helpful
Replaced Laptop Screen Brightness Problems.
hi
-try updating the system BIOS of the computer
-visit support.dell.com
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer
cheers!
2answers
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
1helpful
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Grand Canyon Tech
Grand Canyon Tech
