I can't change the sounds on a timex cube. I can change them once the alarm goes off but when I reset alarm I get the same sounds(birrds) and I want to set to waves.
On the Timex T311, to disable the radio alarm, press the Radio Alarm button once. The Radio Alarm Indicator light should go out and the radio alarm won't sound. If you press the Radio Alarm button once more, the radio alarm will toggle to on and that indicator light will come on. Similarly, press the Buzzer Alarm button once to enable the buzzer alarm and press it again to disable the alarm.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
Timex T307S
I lost my manual also so had to resort to relentless trial
and error.
The problem with the alarm is that it is too easy to turn it
on.
The 1 and 2 buttons on top of the
unit with the alarm clock symbol turn each alarm on or off.Your only cue is on the display in the top
line of the display which will have a bell followed by “RADIO” or “SOUNDS”, if the alarm is armed.If you see this symbol and want to disarm the
alarm, press the 1 or 2 alarm button according to which alarm was on the
display.It’s just as easy to turn the
alarm back on either deliberately or accidently
Enter Alarm Setting mode by holding the 1 or 2 alarm button
for about 2 seconds.
Display will flash – in this mode you will be able to do the
following
Date Set Button – changes between
Everyday/Mon-Fri/Sat-Sun
Arrow Buttons – adjust the time
setting
Alarm 1 (Radio):
Mode Button – changes between
AM/FM1/FM2
1-6 Buttons-- changes between stations
Alarm 2 (Sounds):
Mode Button – changes between SD1/SD2/SD3/SD4/Buzzer
If you don’t change any settings
for about 5 seconds the unit exits the alarm setting mode.
Timex already has your money so I guess they are not motivated
to publish their manual.
