Printronix T5000r Label Printer Logo
Posted on Jul 21, 2008
GAP NOT DETECTED ERROR ON PRINTRONIX T5000 PSN
Hello, can anyone assist me please, the label printer is not happy since we had an office move, perhaps some settings have been lost but we keep getting the 'gap not detected ' error.
any help appreciated!
  • lnc24uk Jul 21, 2008
    hold the 2 buttons on the far right at the same time, this will unlock the enter key, then you can scroll into calibration menu and then calibrate, job done!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
13066
Points
My label printer quit printing the barcodes on the labels.
I am just getting a series of lines.
I have tried unplugging the machine and still have the same result.
I have tried to calibrate but that is not working either.
Thanks in advance for any suggestions.
Brandon
Level 1:
  • Posted on Sep 18, 2019
Brandon
Contributor
Level 1:
Answers
Questions
0
Helped
13066
Points
Seems to be a lighting issue.
We got the air after installing a light right above be printer.
They put a piece of cloth to create a shadow and it worked just fine.
Definitely check the lighting around the printer so the laser can read properly
Ernest Mandla
Level 1:
New Friend:
  • Posted on Sep 22, 2015
Ernest Mandla
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13066
Points
And put your Printer on the Gap mark and run auto calibrated on that Printer your problem wll be solved
thanks
Sachin Miskin
Level 1:
New Friend:
  • Posted on Dec 02, 2013
Sachin Miskin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13066
Points
Every time GAP NOT DETECTED ERROR ON PRINTRONIX T5000 Do you have any suggestions?
Printronix T5000r losing configuration
Log into the printers web page using the current IP address. Login: root password: (no password) click the config link then uncheck BootP, RARP, and DHCP.
Printronix T5000 printhead hot
If this is in a Hot environment or printing heavy this is normal, but if not the head may need replacing.
11helpful
4answers
1helpful
Printronix t5000r "GAP NOT DETECTED"
pls you can checked it by gap adjust lever. it is available in right side of printer.
Error msg says "COLD PRINT HEAD"
1. The Printhead/Controller
cable assembly is
disconnected.
2. The environment is too cold
for the printhead to sustain
operating temperature.
1. Make sure the printhead/
controller cable assembly is
connected to J401 at the
printhead and J6 on the
controller PCBA.
2. Move the printer to a
warmer location.
If none of this works you might have a bad printhead. The thermistor on the printhead has gone bad and needs to be replaced.
Please contact me if a printhead is needed or if you have any other questions. I am also an ASR for Printronix meaning I can supply you with new and used parts and printers.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
[email protected]
AOL IM: RORYMRP
Blank cards rolling out of our Printronix T5206
Hello Frank,
Please contact me directly regarding your problems with your Printronix printers. I am an ASR for Printronix and can help you thru what ever it is you are having problems with.
We are the biggest supplier of Printronix new and used parts.
Rory Cardenas
Account Executive
Midrange Repair & Parts
708-597-4222 x: 240
T5000 Thermal Printer
There are two guides on that machine.
One guide will make sure that the media is locked down and secured. if it isn't it will cause drifting.
There is also another guide around the thermal head before printing that guides the labels before it prints. It either white or or it could be a green color.
are you using the takeup roller on the printer to hold the wax paper? If you are is it straight on the take up roller?
T5304r Printing of PDF Documents
I don't see that it is possible. The SMT tools themselves won't let in an import. The programing or tagging would have to be done by you.
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
