Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RE: whirlpool refrigerator side by side ED25RFXFW01. I accidentally severed the water line inside the freezer door. How do I get to it? It appears that the shelves and insulation are glued to the door, rather than screwed on. This looks like a nightmare.
Bruce Denton
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Feb 03, 2011
Bruce Denton
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
51257
Points
772
The water line can be replaced by removing the dispenser cover and disconnecting the tubing and then pull the old line down from the bottom hinge area. once out, you can install your new line back up into the place it came out of. it goes through a channel inside the door. once back up in dispenser area..connect back to nozzle. the hose under freezer door needs to be connected as well...
1helpful
Ed25rfxfw01. I have an ED25RFXFW01 refrig whose ice maker 'trap door' won't shut all the way( about a half inch gap) when you stop dispensing the ice. Tried to take the clear shield loose to see if it was...
Sadly, you will need to replace the entire 'flapper' assembly for this machine to fix this problem. This is the part in question. 8201649 for Whirlpool side by side. However, I would suggest if you can find the entire control panel assembly (which would be MUCH easier and have less chance to break things) to do that instead.
However, clearing the shoot wont do a thing for this issue at all.
Hope this helps ya ^_^
3helpful
Ed25rfxfw01. I have an ED25RFXFW01 refrig whose ice maker 'trp door' won't shut all the way( about a half inch gap) when you stop dispensing the ice. Tyied to take the clear shield loose to see if it was...
There is a good chance that the clear shield has come out of its mount and is jamming the mechanism. Check to see if this is thae case. It is a bit tricky to get it back in but you should see a tab on the back side of the shield and it clips into a slot on the actuator arm.
Water dispenser not working on my Whirlpool sid eby side ED22TQXGW00. Water is present all the way to the bottom line at front of unit and does pump out when lever is pressed. Problem appears to be in the...
It sounds like you investigated already. If I read this right, you can take off the kick plate and disconnect the fitting coming from the fridge going to the dispenser in the door. right?
And if you hit the button while it is disconnected and water comes out then the line is frozen in the door. Check your freezer temp to make sure it isn't too cold and defrost the unit.. If it doesn't happen again then you are ok but if it happens again then you are either having a temp issue getting too cold in the freezer or there is a void in the door letting the line freeze. That would mean you need a door
Lfx25971 will not dispense water
My water dispensor INSIDE the door froze up.... GE
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
2helpful
Water freezes when going into ice maker model # ed25rfxfw01 whirlpool
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
2helpful
Ed25rfxfw01 whirlpool fridge water dispenser
HI, I can help you. Is the water leaking from the freezer side?
2helpful
TURN OFF FREEZER HALF TO DEFROST WATER LINE THAT FEED ICE MAKER
Just turn the refrigerator off inside on control panel. Then get a hair dryer and melt the ice away from the tube taking care not to get plastic too hot. Sea Breeze
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
